amaranth22
Aerospace
- Oct 11, 2006
- 3
Hi? ALL
I have sandwich panel with solid fitting, the assey is fastening panel and fitting through the hole with bolt.
Fitting constructed with SOLID Elms and SHELL(Laminate) Elms for panel side with core.
Panel base line is OML(tool side), the solid fitting above 1.5in from panel elements as below;
fstr
===.======= <-- Solid Ftg. . <- RBE2(123)with solid node
| 1.5in Core | <- RBE2(12345)
-----.------- <-- Laminate . <- panel node
Solid fitting have fastener hole, the RBE2(123) have center and around nodes at the fastener hole but no hole in laminate panal.
RBE2(12345) have panel and hole center node in fastener hole. Loads applied to panel and B.C at Ftg. end.
I want to more good FE model in this case (large gap) and get the resonable fastener loads.
Please feel free for any comments and advices.
Thank you.
fstr
Thank you.
