Here is a question: on a steel girder, with a field splice, the bottom flange splice plate bolts. I have always detailed splices with the heads on the underside and the stickthough and nut on the top side of the bottom flange. This could apply to bottom lateral bracing as well.
I realize I never knew the exact reason I do this, it's just something I learned and never asked why. My argument is that you can verify the underclearance to the head of nut. A co-worker thinks that placing the bolt head-up is better since if the nuts works loose, you wont lose the bolt.
