illini8181
- May 7, 2013
- 40
I am designing a bolted connection (see attached) which consists of a steel structure bolted to a large, gently curved steel plate via two steel flanges. In between each of the two flanges and the curved plate is a very hard plastic shim.
These are very, very large structures, and so the part tolerances can only be held so tight. Because of this, one or both of the feet will likely be “kicked” at some angle relative to the curved plate, and there will be a slight gap (max of about 0.070 inch, based on GD&T). These are also both very stiff structures, and so we cannot close this gap with preload. Also, we are not allowed to take into account friction in our analysis. The plate is hanging cantilevered off of the steel structure, which is fixed. I am not experienced in analyzing a joint like this, but from what I read, bolts are typically only analyzed for shear and tension. However, the question has been asked whether bending is a factor in this joint, due to the possible gap. Does anyone have any thoughts, or references that might be helpful?
