Boise Cascade - Ijoist - Question
B Leumas
Computer
Jan 25, 2017
I have the BCI iJoists supporting a second floor - there is going the be just sheetrock below the ijoists. My question is - Is bridging needed for iJoists - is it code satisfactory if there is no bridging for ijoist. If bridging is needed - what type of bridging is recommmended - the ijoist are a little greater that 10 ft. Also, 2 joists have darkened due to being weather exposed - no visible damage though - is it safe?
B Leumas
Those are questions best sent to the designer of the joists. All i-joist systems (whether BCI or Weyerhauser or others) should be designed by a supplier. They would be the only ones to comment on the capabilities of their system.
Thanks...but generally speaking do Ijoists need bridging...
Link
Link
it's my understanding that generally speaking they do not need bridging
generally, as I recall, their code reports will indicate such.
suggest get their report and scan through it.... also, sales rep can prob point you to chapter and verse.
I think I would be a little more concerned about needing web stiffeners and not so much bridging. If you have enough load though, and your single sole plate isn't able to support a stud if it lands off center from an i-joist then you certainly would need bridging and hangers for the bridging.
