boiler operating pressure requirments
czarlun123
PH
hello good day. Currently, our power boiler is operating at 33 bars, 370C superheated steam, steam flow at 32 ton per hour. supplying steam to steam turbo-generator, extraction type.
I want to purchase a packaged type boiler to serve as back-up in case the big boiler will be subjected for repair works. The small boiler will supply steam to process only.
Can anyone suggest what will be small boiler specification?
Unless you want to run your generator at some lower efficiency (use non-superheated steam) or lower rating (provide less steam pressure and less steam flow) your temporary boiler will have to be the same rating as the current boiler. How could it be different?
Warning, deliberately running "wet" saturated steam for long periods of time into a turbine designed for superheat properties and flows will likely void warranties.
How much steam at what quality is being take off for process use?
That is your question.
Plymouth Tube
Small boiler will supply only steam to process dept.
at Pressure reducing and desuperheating station one, 3 kg/cm2 180 C, the total steam flow req is 23 TPH.
at pressure reducing and desuperheating station two, 6 kg/cm2 350 C, the total steam flow req is 5 tph.
So what will be the small boiler specifications base on these req? [ponder]
6 kg/cm2 at 28 tph, plus design margin to ensure releif valves do not lift. Find out the desing pressure for the piping from the steam turbine extraction nozzle to the 6kg/cm2 process, and that would be the design pressure for teh steam exiting the new boiler. The boiler's "master stamping pressure" may be 5% higher than that steam pressure.
"Whom the gods would destroy, they first make mad "
