boiler circulation pump
pumposervicio
PH
hi all
pls help me to understand this.
in power plant, why do we need to put a boiler circulation pump to boiler ? what is the use of it? boiler produce steam @ 200deg (c), h= 700m, Q = 50cu.m/hr.
thanks
It is a waste of energy to try to move the condensate back to the boiler using the steam's pressure. Makes the heating loop extremely inefficient
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying ” Damn that was fun!” - Unknown>>
I suspect there's a language translation issue, and pumposervicio is referring to a boiler feed pump, as opposed to a circulator.
It's difficult to know what this circulation pump will do without looking at the drwaing showing where is attached. Generaly in boilers with natural circulation ( where the movwement of water/steam mixture in boiler tubes is acheived by the means of different water S.G. at the bottom/top of the boiler),
sometimes certain portions of tubing suffer from overheating - hence need to add "circulation pump"
Critical boilers ( where SG of steam vs. S.G. of water is similar) need to use this pump(s) to circulate water/steam mixture through the boiler( not your case).
