strainstress
I am working on a blow out panel (hinged on one side). The panel will rupture at 6 psi pressure. After blowout, in order to prevent the panel from damaging building roof, the panel is restrained by four chains (See attached image). I have to figure out the size of chains required.
The approach I took was to calculate the total work done on the panel (See equation 1 attached) and equate it to the potential energy of the chain (See equation 2 attached).
In order to calculate the work done, I applied the 6 psi pressure to the panel and integrated it from 0 deg to 90 deg (See equation 1 attached).
The chain force I obtain using this approach is huge and does not make sense. I understand that the 6 psi pressure will only act before blowout and after blow out, the velocity pressure of the exiting air will perform work on the panel. Is it reasonable to assume the velocity pressure acting on the panel is 6 psi ?
If this is not the correct approach, can you please suggest what would be the correct approach to tackle this design problem ?
StrainStress
StrainStress
