Hi all...
I have an indirect fired line heater with a 50/50 EG/Water bath maintained at 90 C. Gas enters the line heater preheat (first pass) coil at a known wellhead pressure, temperature and flow rate. Under a certain condition, the wellhead ESDV and the angle choke on the coil outlet close simultaneously, thereby blocking in the gas.
With "U" and "A" both known or reasonably estimated, I can use NTU effectiveness to get the process outlet temperature. What I am interested in, though, is an accurate determination of the actual trapped mass of gas in the coil at the time it is blocked in. The ensuing effect of heat input on the gas follows an isochoric process, and the intent is to determine the requirements, if any, for thermal relief. Coarsely, I can estimate the average density (and thus mass) using some form of temperature averaging, or I can use the end states and estimate the average density using some form of density averaging (arithmetic or "2/3 Rule" or otherwise), or I can do something else.
What would be the best averaging method for me to arrive at the most accurate estimate of the trapped mass, or is the arithmetic average density between the two end states close enough?
