Scoomer
- Nov 22, 2004
- 6
I work for a municipality in Minnesota that is currently in the throes of an agressive capital improvement plan for reconstructing residential streets and improving utility service. As part of our street projects, we specify a bituminous joint saw-and-seal after the wear course lift is placed.
The saw-and-seal that we specify is sawcutting a joint 2-1/2" deep. The width of the cut is 1/8" with the exception of the first 5/8" depth for which is it is routed to 1/2" wide at the surface. A bond-breaker tape is installed in the cut with a bituminous sealant to the 5/8" depth. The cuts are generally done about every 40 feet or at every perforation through the pavement (i.e. gate valve or manhole iron) matching the nearest concrete curb joint.
Most of the streets that we reconstruct are typically low-volume residential streets with a few minor arterials. Our main purpose is thermocrack control.
Questions:
1) Does anyone else do saw-and-seal on their roadways?
2) How has it worked out?
3) Can you suggest any modifications to the design above, if any?
4) If you have quit doing saw-and-seal, why? (and if it's a money reason, please provide an engineering justification).
Your advice is appreciated!
Questions:
