I did not mean it was impossible, but it would be quite a task. My experience with phosphates (di-, hexameta-, poly-, and phosphonates) are based on work in a heterogeneous (15%solids)solution that was saturated with NaCL, Na2CO3,Na2SO4 and oversaturated with a gas, nasty!
If you could accept a concept of sample and hold then it would be easier: you could employ a multitasking titrator for nitrate and phosphate (as ortophosphates)determination. With other phosphates a pretreatment of the sample is neccessary.In the same time you can measure pH and oxidation-reduction potential and conductivity. Sulphides can be done titrimetricaly as well. Carbon could be measured with organic/total carbon analyzer but this is another device. Contact vendors of multitasking titrators and insist to make at least 48 hours or better one week tests with your particular water.Carbon is another, quite expencive story.
m777182
