TurboService
Automotive
Im in a pickle and wondering if anyone can help me out. I run a small machine shop here in NJ and the facility has 480v but each unit has a step down transformed (single phase 240).
Anyway, my electrician came in yesterday and installed the 3rd phase into my suite. All of the work was complete and we decided it was time to connect the GX7 Screw compressor. Everything seemed striaght forward, the multi-tap Siemens 160/489VA 4AM3841-8BD40-0CN2 has all of the jumper pins clearly marked on the front.
Little background, my electrician made it clear from the beginning that this unit was originally wired 480v from the factory. Then it was set up to run 240v 3phase at the location I purchased it from. Oh yes it was tested and running when I bought it on the 240v 3phase.
The electrician pinned out the Siemens multitap until he felt it was correct and then explained his work to me. I agreed with him that it looked to be correct so we fired up the compressor and all I saw was a big flash and an explosion. The electrician made it clear from the beginning that this could happen but even he didnt expect this to hsppen.
Does anyone have a clue why this would happen and what the possible culprit could be?
Would this explosion be limited to the multitap or should I be looking for other replacement parts as well?
Is there a lower price alternate to the Siemens 160/489VA 4AM3841-8BD40-0CN2? If so where can I find it?
Thanks for the help, this one is going to leave me flat broke!
Thanks,
Sean
Thanks,
Sean
