Hi All,
I'm an electrical that's coming from mostly experience in software and trying to learn some schematics of our current products.
Can't show it all but had a question about this circuit. We have an IC being fed by a 15V supply, it drives the gate of 2 MOSFETS in sync. Looking at the datasheet I understand all the resistors and caps on each input but I don't understand the purpose of the circuit. If we already have 15V, and we're driving both the driver circuit, and the MOSFETS, then why don't we just pass along that same voltage to the rest of the circuit where it gets bumped up to different values via bias transformer?
Are we using this to make sure the 15V is isolated, regulated, and "clean" from the original source? In that case why not just use 1 switch in a buck boost topology?
Appreciate it,
Appreciate it,
