Hello all!
Attached is a simple sketch of a steel frame. As I have no experience with welding, I was hoping I could get some advice from you guys.
My question is; Can horizontal HSS profiles be welded directly onto the vertical profiles or do you need steel plates of some sorts? All the beams have the same cross sectional dimensions
Cheers
Cheers
