skaboy607
- Dec 19, 2010
- 34
I have drawn the shape below.
I drew it using the line tool and then applying the desired radius I require of 38.1 mm. I then used the 'tube' tool to create the shape with required inner and outer diameters I require.
The inner and outer radius' are smaller and larger respectively. How can I create shape that has my desired radius but on the internal bend?
Thanks a lot
Thanks a lot
