An induction motor equivalent circuit model (including model parameters) can be used to predict a wide variety of operating characteristics of the motor.
The model parameters would be things like R1, R2, L1, L2, Xm, Rm... call them x1, x2, x3 etc for simplicity.
The operating characteristics would be things like Efficiency at full load, power factor at full load, efficiency at half load, no load amps, starting current, starting power factor, breakdown torque, starting current etc.... call them X1, X2, X3, etc.
So we have
X1 = f1(x1, x2, x3...)
X2 = f2(x1, x2, x3...)
X3 = f3(x1, x2, x3...)
etc.
Where
we know all the functions f1, f2, f3
we know selected operating characteristics X1, X2, X3
we want to know the model parameters x1 x2 x3 (so that we can calculate other of the operating parameters which were not initially known).
So the basic stumbling block is that the model is easily solved for operating characteristics from model parameters. We want to reverse it and solve the model parameters from the operating characteristics. No closed for method exists.
So we need to put it into excel. To put these relationships f1, f2, f3 into excel, we need some guess at the values of x1, x2, x3... call our guess x1’, x2’, x3’
When we plug our guesses x1’, x2’, x3’ into the model, we get estimates of operating characteristics X1’, X2’, X3’ where
X1’ = f1(x1’, x2’, x3’)
X2’ = f2(x1’, x2’, x3’)
etc
The goal is to find the value of guesses x1’, x2’, x3’ which will make calculated X1’, X2’ X3’ match the known X1, X2, X3. But solver doesn’t work with multiple equations, it wants to minimize one result. So we need to combine these equations... logical starting point is sume of squares of residual errors.
e1 = X1 – X1’ = X1 – f1(x1’, x2’, x3’)
e2 = X2 – X2’ = X2 – f2(x1’, x2’, x3’)
etc
SSE = e1^2 + e2^2 + e3^3
So you can see we have excel spreadsheet which starts with guesses x1’, x2’, x3’, uses them to compute X1’, X2’, X3’, compare those to targets (X1, X2, X3) to come up with errors (e1, e2, e3)..... which are roled into a total SSE
The user of solver should now be obvious: set solver up to vary x1’, x2’, x3 in order to minimize SSE. If we find SSE suitably low, we may have a good solution.
Actually there is quite a bit more you should do to test the goodness of your solution and look at how the solution behaves with varying initial conditions. One very useful technique for varying initial conditions is to use a weighted sum of errors instead of a simple sum of errors. Run the optimization and use the solution as the guess for the next optimization, but with new weighting factors. Often if you set the highest weighting factor to the error that is the highest, it leads you toward a good solution.
(2B)+(2B)' ?
