S
shaun8567
Guest
I'm trying to figure out the best method for modeling a
beam joining plate, where bolts pass through three
separate components (a front plate, the beam, and a back
plate). I'm currently working with a very simple model to
develop a method that will best model the real case.
Below is a picture of my test model with the loading
conditions.
The two outer plates are constrained and the third middle
plate has a load that will pull the plate from between
the other two. In the real world, four bolts will prevent
this from happening, but the question is: what is the
best way to model this in Mechanica?
Currently I have two methods that comes to mind:
First Method:
The first method uses two beams with a cylindrical
cross-section to simulate the bolt. The two outer plates
have a datum point on axis with the bolt hole and laying
on the plane for the outer surface. These datum points
have ridged links connecting them to the outer surface.
The third datum point is on axis of the third plate in
the middle and the point is midway between the two outer
surfaces. This datum point has a ridged link connecting
it to the hole's surface area. Below is an image.
Second Method:
The second method uses two fasteners to join the plates
together. The diagram below shows the connection layout.
The first bolt joins the front plate and the middle plate
and the second bolt joins the middle plate and the back
plate.
The second method is much, much quicker to implement, and
my gut feeling is that it might be modeling the joining
of the plates in a more realistic way. In reality, the
middle plate will not come into contact with the bolt
unless the load overcomes the friction between the plates
and causes the middle plate to slide. Before this
happens, the shear load is being distributed across the
contact surfaces and the load that the friction will be
able to handle will be dependent on the pre-load
(compression force) and the coefficient of friction.
It should be noted that the final model will be using
midsurfaces since the material thickness is on the lower
end.
Thoughts?
conditions.
First Method:
Second Method:
plate.
end.
Thoughts?
