Best dP correlation for two-phase steam?
KernOily
Petroleum
What correlation have you guys used with good success to calculate dP for two-phase steam? I am using Beggs-Brill-Moody but it's not a very good match with the field data - the error is about 20%, which is too high. This is a 70% quality, 550 psig system. I also tried Dukler and LM but they were worse.
Any thoughts/ideas/miscellaneous ramblings welcomed... Thanks!
Pete
pjchandl@prou.com
Spirax/Sarco has a table that indicates steam leaks to ambient through various sized orifices at various pressures, but it didn't seem to indicate steam quality. I assume the table relates to saturated vapor. Interpolating from the table, 550 psig through a ½" orifice would give 3,430 lb/hour flow. What is the opening size?
Have you tried Bernoulli's equation (using 1.57 lbm/ft3 density at that quality)? -Chas
In europe the big fuss is OLGA. It has a SS HYSYS plugin. Its not something you can "do by hand"
Try this link:
Best Regards
Morten
Beggs-Brill is good for only for cross country pipeline/flowline having diameter 8 inch or less.For small lengths (e.g. inplant piping) and where the total pressure drop is less than 10% of the inlet pressure, API-14 E equation gives the better results.
Beggs-Brill is good for calculating the pressure drop in cross country pipeline/flowline having diameter 8 inch or less.For small pipe lengths (e.g. inplant piping) and where the total pressure drop is less than 10% of the inlet pressure, API-14 E equation gives the better results.
When you say API 14E gives better results, have you done the calcs and checked them against field data? Thanks!
Pete
pjchandl@prou.com
Bernoulli's equation is an energy balance equation. It has the friction loss term in it so I still need some way to calculate the friction loss.
I should have mentioned that I am using the PipePhase software to do these calculations - I am not doing them by hand.
So far the best match is with the Dukler equation, with BBM in 2nd place. The problem is - the correlations are overpredicting the dP by a huge margin, like 200%, relative to the field data, on the longest runs of pipe (several thousand feet). I guess I will have to manually adjust the pipe to make the correlation match the field data. The problem with that is - it fouls up the heat transfer calcs, which fouls up the accuracy of the steam quality predictions... oh well... Thanks!
Pete
pjchandl@prou.com
