Best air flow measurement method?
CnoJ
I often need to know mass flow rate through air cooled industrial equipment and usually struggle to get repeatable measurements using vane or hot wire anemometers. I can only measure at the intakes, which are up to 700mm (~28") sq with flow in the 1500 to 5000 CFM range. Fan pressure is usually around 200-300Pa.
What methods or equipment are most accurate for measurements like this? Set-up time and cost aren't big concerns as much as getting measurements with a known accuracy (is 5% asking too much?).
All suggestions/comments appreciated.
Thanks,
Jon C
I haven't found a hood that will cover my CFM range, they seem to stop around 2500 CFM.
Would a pitot grid be my next best option? Is there such a thing as a hot wire anemometer grid?
The company I used to work for helped Kurz Instruments with a plethora of mass-flow instruments for measuring all kinds of flows. Even the mass-flow thru Moss Landing's stacks that are about a hundred feet across.
[URL unfurl="true"]http://kurzinstruments.com[/url]
Keith Cress
kcress -
