How do you determine the material length needed prior to bend round bar in to shapes, specifically I'm bending J-bolts and U-bolts with square and round bends.
My problem is in calculating the initial material length to compensate for the bending, are there any references for this anyone knows of, or standardized J-bolt/U-bolt equations. The length of material prior to bending is often called "Developed Length".
If there are no reference tables, should you calculate the circumference of the pin the material is being bent around and then add the straight lengths? Or do you need to get circumference for some point inside the bar to compensate for its deformation?
Any help appreciated.
