Bend sheet plate (to known diameter)
  • Thread starter Thread starter intogtar
  • Start date Start date
I
intogtar
Guest
Hello all,
I have flat plate where I should draw holes and after holes are done I have to bend it to an arc shape with radius of 154mm. How it can be done?
I have attached an image with drawing in AutoCAD. How I can make this in 3D using CATIA?
THANK YOU!
The easiest way for a simple part like this is to use the Sheetmetal workbench.
Can you please tell what exact tools should I use to get my flat plate with holes to the round one?
Thank you!
Sorry, but I don't have access to CATIA right now and can't verify all the exact steps.
If you know how to use the Sheetmetal workbench, the process is fairly simple:
1. define the curved plate
2. unfold (flatten) the part, and add the holes
3. fold the part (with the holes) back to it's curved shape
If you're new to CATIA, I suggest you get some training.
OK Intogtar, here's the exact steps: (based on CATIA V5, R18)
1. Use the Generative Sheetmetal workbench (SMD license), and start by using the SheetMetal Parameters to define wall thickness and other material properties
2. Create a Sketch of the side profile of the the curved plate, with bend radius and enclosed angles
3. INSERT + ROLLED WALLS + ROLLED WALL, select profile sketch, and speciafy the length of plate
4. INSERT + VIEWS + FOLD/UNFOLD to see flat, developed shape
5. With unfolded (flat) shape;
5a. create a sketch of the hole
5b. INSERT + CUTTING + CUT OUT, and select sketch of the hole
5c. INSERT + VIEWS + FOLD/UNFOLD to see curved plate with deformed hole
repeat for more holes
6. With folded (curved) shape;
6a. create a sketch of a another hole
6b. INSERT + CUTTING + CUT OUT, and select sketch of hole
6c. INSERT + VIEWS + FOLD/UNFOLD to see flat plate with this hole developed in flat
7. to make a drawing view of the developed (unfolded) plate, use the UNFOLDED VIEW tool in the Drafting workbench and add dimensions
Notes on my last post:
1. The icons can be also be used for the all the steps. I listed the INSERT menu commands because they are easier to type in a posting like this.
2. I used CUTOUTS and sketches to define the round holes. The HOLE command can also be used.
3. I used the Generative SheetMetal workbench (not the Part Design Workbench) to build the solid model. Note the different features in the tree, and also the different set of icon commands:
I tried to identify each feature with a different color, but it's difficult to see - sorry
4. This part could be done with other CATIA methods - I think this was the quickest and easiest.
5. I found out there is a limit of 5 images that can be inserted in these posts.
