How to activate the sheet to which the selected view belongs?
Mirme.lee
Aerospace
KR
Catia Drawing..
What is the VBA Code that activates the sheet to which the selected view belongs? I plan to use the selection function to select the view.
I think that the sheet is allready activated if you have selected a view.
Here the code to retrieve the sheet name:
Code:
Sub CATMain()
Dim Document1 As Document
Set Document1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = Document1.Selection
Set myview = selection1.Item(1).Value
Set mysheet = myview.Parent.Name
End Sub
Marc
CATIA.ActiveDocument.Selection.Item(1).Value.Parent.Parent.Activate
Thank you all.
Thanks to you, my work has become easier.
