Bend lines - Up or Down
plcorriveau
CA
Is there a way to show on a draft which side the sheet metal has to be bend to get the final piece ? Often, there are draft reading mistakes when a piece is fold and I'd like the draft to be clear on the side of the bend to be make.
Um, detailing the finished form as is standard in most drawing systems achieves this - or am I missing something?
I have attached a screenshot of one of our drafts which we then save to a dwg and email to the lasercutting guys. We use the "Bend Table" function to add the bending lines. We use a "Quicksheet Template" so it is only a matter of seconds to create a draft like this.
Theodore
Solid Edge ST3 MP5 on WinXP x64
Insight Server on Win2008 R2 & SQL 2008 R2 x64
SharePoint 3.0 x64
 http://files.engineering.com/getfile.aspx?folder=96c3c584-686f-4150-b067-f334cd9c0f3e&file=SCREENSHOT-02.JPG
have a look in the bend table properties - this will give you the format to can use in your callouts, for example -
BEND %IA %BO.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
