I've just found out that I can't apply Bend option to an Extruded created solid in Sheet Metal.
I do have a logical explanation of why using Extruded, instead of Tab:
I want te reduce the number of using an additional operation (Cut, Slot, etc) for the final profile I want to create.
I have the feeling that a good designer should create a part using as less feature as possbile.
So, why Extrude option in Sheet Metal, does not accept a bend operation?
