A buried pipe will have a 90deg. bend and a riser coming out of the ground. The steel pipe size can vary (6"-24") and will be buried up to 48" below grade. It needs to have a concrete pad under the 90 deg. bend. I would like to know how I would calculate the dimension of the pad and whether the pad needs to have re-enforcement in it. I know the weight of the pipe with liquid in it.
