I've got 20 Belleville spring washers arranged in pairs 2up, 2down, 2up, 2down....around 1 pin. To test I compressed the set of springs to half its overall length on a hydraulic press. Got a pressure reading of 120PSI. Spring dimensions are OD=22.5mm, ID=11.2, s=1.25mm, Ho=1.75mm.
What load does this equate to? How many kg can it hold at this compression?
Thank you
J
Thank you
J
