sfinlayson
I am designing a ringwall for a steel tank. The tank is 110 ft in diameter and 45 ft high, filled with liquid asphalt. I am trying to determine my bearing pressure below to size the ringwall width. I am assuming that the weight of liquid resting directly on the ground goes into the ground and the weight of liquid directly above the ringwall goes into the ringwall. Is this a reasonable assumption? Based on my weight and moment due to wind (controlling moment) and a bearing capacity limit of 2500 psf, I need a ringwall that is 3'9" wide. For those of you who have a lot of experience with this type of design, does this width sound reasonable?
