polished
Materials
- Jan 6, 2006
- 3
For years I have been trying to find a bearing which will allow a hub to gimble at the end of a spindle, and support 1000lbs of axial load. The machine loads, processes, and unloads on a regular basis, which accounts for regular impulse load higher than the operating load of 800lbs. This is where I believe the bearing failure I am experiencing is occuring. 2206 and 22206 bearings eventually fail in the outer race, or dig pivots in the inner or outer race (the bearing does not rotate so the balls are always located in the same spot) preventing the hub from gimbling. I have also tried a maintenance free sperical plain thrust bearing (GAC-30F) and two different sizes of maintenance free plain sperical bearings. The problem with the spherical bearings is the liner wears, cracks, or is pressed out, leaving metal on metal contact, and once again, preventing the hub from freely gimbling. As the bearing is not easily accessible, maintenance free was thought to be the way to go.
Is there another bearing style or type that would be better suited. There is not much motion in the bearing. It simply needs to keep the hub parallel to the table below it as the spindle it is attached to rotates, as well as transfer the load. Torque is transfered seperately. The bearing sizes mentioned above is about as much room as I have.
Since the impulse force seems to be the wearing factor on the bearings, are their dampeners on the market which can be placed in line with the bearing?
Any ideas are welcome?
