BEAMS TO COLUMNS FIXATION ( IN ETABS) 1
SAYATTIA
SA
GENTLEMEN:
I NEED YOUR ADVISE ,HOW TO CONSIDER THE BEAM TO COLUMN FIXATION OF THE ATTACHED 2 CASES WHEN THE BEAM IS RESTING ON EDGE OF COLUMN.
PLS REFER TO THE ATTACHED SKETCH.
You can use cardinal points to specify insertion point. The ETABS Manual has a good description.
If you don't find it, let me know and I can scan and post that page.
please send me the supporting paper.
pls also guide me how to apply for such case on the sketch attached to my message.
your assitance is highly appreciated
In the help menu, search for "Insertion Point". This will show you the steps.
