Take a look at the attached simple beam layout.
If a person is working thru simple beam design at beam 1 and beam 2, what is the unbraced length that would be used to determine the allowable stress?
- BM1 and BM2 are sitting on a concrete wall and welded down (pinned, not rotationally restrained....except beams can not rotate along about their length)
- BM3 is attached to BM1 and BM2 by typical double angle bolted connections
- BM1, BM2, and BM3 are all the same size, W12 members
One side of me says the unbraced length for beam design of BM1 and BM2 is 10' because BM3 prevents the top flange (compression flange) from laterally moving under lateral torsional buckling
Another side of me says 20' because there's no diaphragm there
This is giving my mind a fit!!
