mbstruct
- Jun 28, 2018
- 5
Lately, I've been designing steel connections on a few projects. I've seen several typical details from engineers indicating full depth transverse stiffeners to be provided in the web of beams supporting gravity columns from above, regardless of load magnitude. Transverse stiffeners are typical specified if web local yielding, web local crippling, web side-sway buckling, or web compression buckling are of concern. I was wondering, if a pair of double angle connections occur beneath the concentrated load, is there any research available on whether or not those double angle connections provide any reinforcement for the local failure limit states similar to a transverse stiffener? My thought is that you have a beam and connection available to brace the web in question, similar to what a transverse stiffener would do. Any input would be appreciated!
