Hello
I have a 250x90PFC and a 300x90PFC that will be supported by 3x90x45 F17 KDHW tripple studs either side. The beams are used on brick veneer walls in a residential home to support upstairs internal framing and bricks.
A 200mm flat plate will be welded underneath the beams which will support bricks on the external side of the wall. The plate will protrude outward from the internal wall to the external
Does anyone have a typical connection detail for how to secure this beam onto the studs?
