All,
I have a steel structure (built approx. 1974 to 1978) with some column deterioration at a girder connection. The girder to column connection is a bolted extended end-plate connection which is welded to the web of the girder. At first glance it appears this is a moment connection, however the flanges of the girder are not welded to the end-plate. In fact, the top flange is not even in contact with the end plate. I've attached a photo of the connection (in good condition). Note, we do not have any documentation of the original construction, however it is known that the beam seat and stiffener plate were not part of the original construction and added by another engineer about 10 years ago.
I would like to know if anyone has seen a similar connection and if they can give some quidence into its original design. I have done some research, but cannot confirm if it is intended to be a partial-strength connection to reduce the simple span moment on the beam or if it was originally designed to be a shear connection. Any one have some insight into this?
