Good day.
I've had a tussle with this for a bit, and just now decided to break down and float it out for community assistance.
In the scenario which is at issue, we have a "black box" load which may be essentially resistive or may be partially inductive; but has been precharacterized to consume 1000W RMS @ 100VAC (10A).
Now, we have a shortish cable feeding power to this "black box" load, which furnishes a "purely resistive" component of .1Ω to the overall mix. If anything ever stuck while studying these things, Ohm's law would seem to be directly applicable in the process of effectively elucidating the (cable) circuit element, and ultimately determining the power loss through the cable:
E = I X R
E = 10 X .1
E = 1VAC (RMS)
P = E X I
P = 1 X 10
P = 10W (RMS)
5th grade simple.
Assuming all this is so, would there be any sound reason to complicate matters with Kirchhoff power law computations to elucidate the purely resistive cable element? I've seen this hinted at; and, in my humble opinion, such a proposition seems akin to going duck hunting with a Howitzer...
Finally, this has been bugging me too: Who do we credit with the original elucidation of electric power (P = E X I)? Ohm? Watt? Joule?
Thoughts?
Thanks!
E = I X R
E = 10 X .1
E = 1VAC (RMS)
P = E X I
P = 1 X 10
P = 10W (RMS)
5th grade simple.
Thoughts?
Thanks!
