chrislaope
I have a question on Base plate Slot Size Limitation for Anchor Bolts.
say for a 1" anchor bolt, AISC-13th, table 14-2 gives a maximum base plate hole diameter= 1 13/16". How about if it is a slot say phi-1.5" by 3", that in short direction it is within the 1 13/16" limitation, but in long direction it exceeds 1 13/16" limitation. Will this base plate slot allowed by Code?
Thanks.
Thanks.
