Dear all,
We subcontracted the fabrication of a 2in thick pressure vessel (in SA 516 Gr70 N). To back-up the WPS´s the fabricator is showing us a PQR which was done using SA36 as base material, whose tensile strength is 58ksi (minimun).
Surprisingly the two tensile tests broke just above 70ksi which seems to be fine.
My questions are:
a)Is it reasonable that a SA36 base material has a much higer tensile strenght than specified (as it didn´t break @70ksi)?
b)Does the code requiere that PQR qualifications must be done in base material of same mech. properties as the one to be used in production or just to have the same P number?
Thanks in advance
My questions are:
Thanks in advance
