Barrier Fluid FDA low temp 1
Seal80
Materials
Hi There
Are any of you guys using an FDA compliant barrier fluid that can run at between -100C and +150C?
Currently a Dow product called Sylterm XLT is being used. This is very hard to get hold of so we are looking for an alternative.
Do you have any suggestions?
Many THanks
S
Flowserve Corporation has a synthetic oils line designed for sealing system. They are called Duraclear and FDA compliance.
Hope it can help you!
Mario Souza
Application & Product Engineering
WMF Solutions Brazil
Try Royal Purple. This is an excellent oil to use for your application.
Thanks..
I think it will have to be Royal Purple although their lowest temperature limit is -65C. I am currently waiting for viscosity data from the supplier.
S
