KimBellingrath
I have a problem to solve
we have a vertical inlet duct 51"L x 26"W that needs heat added to it using the following criteria:
injector pipe: .62dia x 51"L
psia = 57.8
temp = 375F
mass flow* = .17 lbs/sec through 11 pairs of horizontally opposed .125"dia holes.
How can I optimize the flow down the entire length of the pipe by varying the hole diameters?
*this has been calculated to add required heat load to flow
psia = 57.8
temp = 375F
