shashankTurbomachine
We all know that BLO is required in multistage between bearing pumps(BB2/3 and 5)
BLO is a line in which some flow is taken from discharge side(balance drum on BB5,throttle sleeve on BB2/3) and routed back to suction
This flow from final stage of pump has some undergone some heating beacuse of pump inefficiencies thus this flow may flash to vapor and may cause some distrubance to suction.
BLO routing is always done thru bottom of suction becasue of saving in length of pipe and least amount of P.E.(i.e., static head)
which otherwise if routed from top will have liquid fleshing.
I want to know the thumb rule for this flow.
I know this flow is generally 2-5% of total flow.Hence the rated flow shall be chosen accordingly. AS we increase rated flow in case of warmup flow and RO.
Kindly thro some light on above.
A well phrased question has answers in itself!!!
