Assuming that coring confirms a low 28 day break, we are planning on removing a section of a concrete wall we are building. Wall is 18" wide and the section to be removed is 9'x30'. Section is defined by a construction joint along the bottom with steel reinforcement in the upper wall lap slicing with steel protruding from the lower pour. Steel is #8's at 6" on one face and #6's at 12" on the other.
My question is, are there guidelines on the size of jack hammers or other demolition equipment to use in removing the concrete from the lower steel so as not to cause damage to the lower pour's concrete and steel? For example, use a 15 lb hammer within 1 ft of the construction joint? My fear is that they would use a large back hoe mounted hammer right up to the construction joint resulting in unseen cracks in the lower pour.
Any suggestions or references would be appreciated.
