Hi all,
I am designing a pumped system which will be transferring mildly saline nutrient rich water around an aquaculture project. The animals are very sensitive to H2S at low levels, which is going to form if the water sits in the pipes and goes anoxic. Is there a way of configuring the pump so the column of water can run back through, without having to have manually or otherwise operated bypass valves?
Googling provides a lot of info regarding backflow prevention, and it seems is geared towards preventing the kind of flow I'd like.
cheers,
GAllen
cheers,
GAllen
