cheng,
You really should start a new thread for a new question, but your question was nearly close enough to the original question and I'm avoiding work this afternoon.
Design standards for launchers/receivers are a bit thin on the ground, things like kicker/bypass size etc. vary widely from designer to designer.
One thing that you really need to work on is terminology. If you start at the tee and work backwards then:
- The "side valve" comes off the branch of the tee
- The "barrel isolation valve" comes off one of the tee runs (the other goes to the pipeline)
- The "throat" comes off the barrel isolation valve
- The small side of the "reducer" comes off the throat
- The "barrel" comes off the large side of the reducer
- The "closure" comes off the barrel
- The "kicker" (for launchers) or "bypass" (for receivers) enters the barrel (hopefully fairly close to the closure) and connects to the pipeline outside of the side valve.
OK, with terms defined, the side valve, barrel isolation valve, and throat are all the same size as the pipeline (not smaller, think about it, that would be stupid how would the pig get in?). The barrel and closure are the next readily available pipe size larger than the pipeline (e.g., for a 10-inch launcher, the barrel will generally be 12-inch).
With your example, the barrel isolation valve, side valve, throat are 12". Barrel and closure are 16" (they can be 14", but 14" pipe is not generally available). There are a lot of theories as to size of the kicker/bypass, I'm not going to go into all of them. My approach is to stay under 200 ft/sec at normal operating pressure and design flow rate. For a 12-inch with a normal operating pressure of 100 psig, I generally end up with a 6-inch kicker/bypass. At 600 psig (if I'm confident that this pressure will be normal for a long time) then I'll drop that down to 4-inch.
David
