Dec 13, 2021 #1 Ed555 Industrial Joined Sep 20, 2021 Messages 9 Location US If a nozzle is to be welded to a standard pipe cap, should the pipe cap now be calculated as a 2:1 elliptical head instead of straight pipe since it is being modified from its original form?
Dec 13, 2021 #2 LittleInch Petroleum Joined Mar 27, 2013 Messages 22,902 Location GB Yes I believe so as there is no allowance for cuting holes and welding to fittings in B16.9 as far as a I can see, unlike e.g. a blind flange. Remember - More details = better answers Also: If you get a response it's polite to respond to it. Upvote 0 Downvote
Dec 14, 2021 #3 r6155 Mechanical Joined Jan 12, 2010 Messages 2,990 Location AR You need to calculate the required nozzle neck thickness and the reinforcement (ASME VIII-1 UG-45 and UG-37) Regards Upvote 0 Downvote
