Mccoy
Geotechnical
- Nov 9, 2000
- 907
Hello everyone,
I strongly suspect that the cracks manifested in a residential building are due to drilling operations, carried out in successive phases and in a long time stretch.
Subsoil is silty sands, loose/medium loose, with sandstone boulders up to 10-12 meters of depth; bedrock is OC clays. Groundwater only seasonally present in sparse thin perched acquifers, and at the sands/clays interface.
Building is RC beam foundation, masonry structure, 3 storeys. Pattern of cracks (not serious - serviceability limit is not reached)would suggest a non-uniform settlement of the foundation beam more exposed to vibrations coming from drilling ops. Cracks are clustered in the uppermost floor.
The beam is 4 to 8 meters away from RC shafts drilled with rig & bucket,quite a few boulders have been found below 2 meters of depth. Shafts have been drilled twice (successive consolidation operations).
Cracks have started after 1st drilling phase.
4 years after start of cracks micropiles for foundation consolidation have been drilled along the beam. After that, crack pattern worsened. Successively cracks have slightly increased their extent, then stopped after 5 years from micropile drilling.
On top of that, there has been vibrations coming from dozers, and farther away from more rig machines involved in
slope consolidation and earth moving ops.
Is it possible that sands have been compacted by drilling + rig machinery?
Do you have analogous experience in similar conditions? And what about vibrations coming from micropile, drilled not thru but very close to foundation?
The slope below the building collapsed (a small landslide), but the closer tension crack was at 20+ metres of distance - and cracks started a few months after landslide, just after inception of shaft drilling.
Thanks in advance for your opinions.
![[worm] [worm] [worm]](/data/assets/smilies/worm.gif)
