Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
but why they are doing a half-assed job?
so I had this wrong the note on the fiquire contradicts the free state symbol.As all ways I am scratching my head.
But my assumption is hollow or tube like parts are
Flimsy. And even thou are in size. Have to be
In the restrained condition. In the old days
A note was applied (inspected in the restrained condition) in the example above a fixture is required, mounted on A & B.
Thus intent it will assemble, runout acceptable.
Is this a correct assumption?
Burunduk"
This is wrong. If the tolerance is applied at free state, there must be no clamping forces or elastic deformation when the part is positioned for inspection. Be careful with AI.
- For example, if a hole is specified with a free state tolerance for perpendicularity, the tolerance would apply even if the hole deforms slightly due to a clamping force. "
Yes I agree, but technically it's not restraing it's locating. But I am cutting hairs.mfgenggear,
At free state you may still need to support or hold the part in some manner, by devices used as datum simulators, but not only.
Datum simulators could be a granite slab, angle block, v-block, centers, etc. However, you don't clamp to them by force at free state. If the part deformed when you fixtured it for inspection, that is not a free state measurement. Free state is the default and as such it does not normally need any indication on the drawing, except for those cases in which a restrained condition is required by a drawing note. A restraint note such as shown at the bottom of the figure in OP's post overrides the free state default. But unlike that specific figure, often it applies UNLESS OTHERWISE SPECIFIED. Then the otherwise specified controls or datum references are the ones indicated by the free state symbol (circled F).
