Availability of Joints for above 450nm torque
studog
Automotive
Jun 12, 2003
I'm interested to know if anyone can help me source joints for a carbon fiber(possibly) prop shaft, more than likely steel to withstand 450nm torque. As I am in Japan a location in asia may be best! Any advice appreciated. Volumes would be reasonably high.
What sort of joints? Steel CV? Rubber donut? UJ? 450 Nm is peanuts, any automotive component for a car with a 2 litre engine will handle it.
Cheers
Greg Locock
Thanks Greg,
Look if you take a look at the Toyota Landcruiser V8 as an example, the engine was detuned to minimise the torque, and so they could fit 'normal type' couplings and cv's. I have an 'engi' here tellin me that it would be expensive, or rather difficult to source cv's that could withstand 450nm for a steel propshaft. I didn't think that was true given the number of high torque engines in the US(remember I am in Japan). I know the Z car has a high torque engine as well as the GTR and I am aware of the specs of the prop shaft and cv's used in those vehicles. They are somewhat different to this exercise tho'.The use of a steel shaft rather than carbon fiber one has me wondering about the joints necessary(I don't think a joint off any ol 2-cylinder would do the job frankly)to support the shaft. I am of course talking about a performance vehicle for the shaft. Any ideas? Thanks.
You said 450 Nm. You did not say a 450 Nm engine, driving a transmission. Hence my answer.
What sort of joints are you after?
What is the first gear ratio?
If it is an auto what is the torque ratio of the TC?
As you say, there is no shortage of cars around with 450 Nm engines, there are plenty of suitable components.
Cheers
Greg Locock
