automate pattern tables
tazengr
34
I used the faq in the forum that automates pro engineer models thru the use of excel.
Here is the link
I can do this for simple dimensions that are in a sketch. But I would like to do this for making several patterns per model.
Q.
Is there a way to automate the creation of patterns through the use of pattern tables?
Thanks,
Tazengr
You can create pattern tables manually then read them in. Using Notepad or other simple text editor you can create a lot of tables in short order.
Also remember that an Identical pattern can be converted to General pattern governed by a table. The table is created by Pro/E in the conversion. In this way you can delete or suppress members of the pattern (except, maybe, the leading feature). That can't be done with an Identical pattern.
Tunalover
