Zeus It depends upon how you dimension the sketches when you model the part. If you dimension the part as you would layout the item when it is manufactered, then autodims are viable. But if you have a lot of C-lines and reference dimensions layed out to make the sketch, the resulting mess may cost more time than its worth.The good part of autodimensioning is the dims are accurate as far as how you designed the part.I usually autodim and then edit,delete redundacy,dimension from a common face/datum, ect.I have not actually timed what way is fastest, but I have found also, sometimes a paticular piece of my design is really hard to accurately dimension in the real world.Then I usually go back and redesign, redemension the sketch so it is easier to solve the dimensioning bottleneck.
