Autoclavable Plastics
Jen123
I am looking for autoclavable plastics for a water process application. The specific requriements for this material will be:
(1)cost effective
(2)can be autoclaved repeatedly at 121°C/15 psi
(3)biologically compatible
(4)easy to machine and easy to seal with gaskets.
(5)working environment will be groundwater with neutral pH, temperature will be 0-35 degree C.
With preliminary research, I found the following materials which are autoclavable:
Polypropylene (PP), polypropylene copolymer (PPCO), polymethylpentene (PMP), Tefzel® ETFE, and FEP and PFA.
Any suggestions for choosing the right materials from the above list based on the requriements I mentioned? I am not good at materials and any input will be greatly appreciated .
Thanks,
Jen
PP will probably warp at 121 deg C
TPX (poly methyl pentene) will do the job but is expensive and in short supply last I heard. The source is Mitsui.
The injection mouldable fluorocarbons should be OK but expensive.
Have you looked at PPO. It is used extensively in hot water meters, but I don't have actual data here. The most common name is Noryl.
Ultem and polysulphone might also be possibilities.
Pat
for site rules
Hello Pat,
Thank you very much for your input. Noryl seems a strong candidate for its low cost as an autoclabable and biocompatible material. Ultem and polysulphone look good too. Thanks again and I really appreciate.
Best,
Jen
