AutoCAD LT 2005 publish 1
Guy405
Computer
I know the publish command is a terrific way to save time when printing multiple sheets. Is there are way to publish 'plot to file'?? Or do I have to click the sheet #, click plot to file. Print. then repeat 100 times?
tHE ABOVE LINK SHOWED THIS;
Reply From: R.K. McSwain
Date: Mar/10/06 - 23:05 (GMT)
Re: To create PLT file using publish command
mKam said the following on 3/10/2006 4:04 PM:
> In AutoCAD 2006, is there anyway to publish (batch plot) to file to create PLT files? I can do so one by one, but cannot figure it out when I use PUBLISH.
> Please help!!!
Configure your .PC3 file so that it plots to file.
Where is my .PC3 located? And which lines do I need to configure to be able to 'plot 2 file'?
(I am sending these PLT files to a printing company, otherwise I'd make multiple dxf files)
Under FILE >> PLOTTER MANAGER should be your plot setups (PC3's). If you don't have any then you are probably using system printers as the setup. You will have to ADD-A-PLOTTER and then set up a new pc3. WHen you get to the part about PORTS (a tab I believe), select plot to file as the selection. I hope this is helping.
"Everybody is ignorant, only on different subjects." — Will Rogers
Ah ha! Thank you so much Mr (or Ms) Guru
