AutoCad Dimension - Change Text Size
Beammeup
I have a 3-D piping isometric CAD drawing that I created using AutoCad LT for Windows 95. When I print it out in paper space, the text is too small to read. How do I change the dimension text size to a legible size?
Hopefully, the drawing uses dimension styles. If so, edit the dimension style (DDIM) and on the "Fit" tab, check mark "Scale dimensions to layout (paper space)"
You can also change the height off the textstyle. But be careful. All off the text placed on that textstyle will be changed to this height.
mvg
HMO
